Selector switch...selection
For a first project I would like to replicate a design like this:
Goal: switch 1 input between 4 outputs.
For the rotary switch, is it correct that I need a 2-pole, 4-position, non-shorting switch?
And, if you can recommend one, I would a appreciate that too!
You might consider switching using miniature relays; saves on complexity of the switch and the signal is not routed as for. There is a thread about this on DIYAudio. There are also designs which can be used as a template, if Googled.
