For a first project I would like to replicate a design like this:
Goal: switch 1 input between 4 outputs.
For the rotary switch, is it correct that I need a 2-pole, 4-position, non-shorting switch?
And, if you can recommend one, I would a appreciate that too!
These are cheap and cheerful and of decent quality. All have adjustable end stops so either would work OK.
LORLIN - CK1051 - SWITCH, 3 POLE 4 POS | CPC UK
LORLIN - CK1060 - SWITCH, 2 POLE 6 POS | CPC UK
Those Lorlin switches are very good value for money. You could make something a lot better and cheaper than that design from Douk
if it's advertised for audio, fair to assume it's non-shorting as well?
I thought so. Smaller too...i'd probably 3D-print an enclosure (unless there would be shielding issues...maybe better shielded wires?).
You could get away with shielded wire in a plastic case. Personally I'd use metal enclosure as well
- Design & Build
- Parts
- Selector switch...selection
