I would like to install a selector switch on my BOZ to select between 2 different inputs, a sacd player and a music streamer(squeezebox).
I think what I'm looking for is a 4P3T type rotary switch but I'm not
sure..😕
Could some body suggest something that I could use that's not
super pricey ??
Thanks...😀
sure..😕
super pricey ??
Thanks...😀
Will that do justice to my BOZ ??
I just thought that rotary switches would have better quality contact surfaces....
I've had good luck with the switches I've used, didn't seem to sound any different...and the B1 used a toggle 🙂
I have settled on a Grayhill selector switch(because I have one onhand😀)
So when switching sources is it ok to just switch the signal wires?
I have all my grounds going to a "copper ground plane" and would like to leave them there and just switch the signal wires....
rtate
Try this:
http://www.hificollective.co.uk/pdf/selector_blue2l.pdf
potentiometers, switches and attenuators homepage
Hope this helps
JC
Try this:
Hope this helps
JC
- Selector Switch for BOZ
