Selection of tweeters for pair
Can you please tell me which permissible scatter in sensitivity can be between a pair of tweeters? For example, on Twitters Dayton indicated 89 0.2 and 89 0.4 This can be considered a selected pair? Or for example 89 0.2 and 88 0.4 This can be considered a selected pair?
If there is a series resistor to adjust level, this can be also used to compensate for sensitivity differences.
The change in resistor value would probably be small enough that the high pass capacitor need not change.
Differences in sensitivity between two examples of the same tweeter are not normally discussed here as the manufacturer will hold these differences within acceptable limits.
It may be that you are worrying unduly.
Can you give a link to where you are getting the selected pair information?
On tweeters there is a sticker. It is difficult to find absolutely the same pair . I have a few but they all differ. I am about it.
