I am going to build a low noise (hopefully) amplifier for a MC preamplifier. It will use 2 2sk170 transistors.
I have both the 2SK170GR and 2SK170BL in my box. The bias should run 3 - 5 ma or so. Is there a performance advantage to using the lower current spec'd GR series?
My phono uses the BL series, but they operate closer to the range of the GR.
tia
George
tia
George
George,
no, i see no advantage in the lower current GR.
And yes, it will be low noise.
I have built a MC amp with them ( don't remember wich type K170 I used ) cascaded into the cathode of a E88CC just like Allen Wright does.
I can only say that it's the most quiet and musical MC amp I ever built.
Dick.
Dick.
