Seen this ? Pros & cons.
I was just "fiddling" with a amp circ when the idea of a half mirrorstarted...
Each of the collector currents is half or the resistor currents. That means resistor inn current has two equal outputs with halfinput as output.
So i ended up with somthing like the attached shows.
Comments mutch welcome !!
