I assume that the tube rectifier must be pulled before using the switch to bring in the diodes. Is this correct?
thanks.
You can switch between tube and SS anytime, you do not have to remove the tube.
When switched to SS the tube heaters will still be glowing but the SS diodes are doing the work.
