Last December, reference was made by Ed LaFontaine to a Seas waveguide tweeter that Madisound will be stocking shortly.
Madisound lists lots of Seas products, has it been released - can anyone direct me?
Joined 2003
Guess not
Doesn't look like anybody's used it yet. I'd think an interesting use for it would be as a tweeter with a supertweeter, to make the best use of the increased efficiency in the 2-8kHz band. An 8k first order XO would make a pretty good 2nd order slope, and you could cross in the little dayton ND20-FB4 above it and have a composite tweeter with excellent controlled dispersion, wide bandwidth, and very low distortion. I'd probably change out the metal dome in the waveguide tweeter for the matching soft dome to kill that ultrasonic peak.
A complicated usage to be sure, with some issues that no doubt would need to be addressed, but nevertheless, probably has a lot of potential.
Yes the FR indicates it needs a supertweeter.
Daytons are sold by Parts Express, I wonder if Madisound ~ who sell the Seas ~ have something similar.
Not sure if this is the same tweeter, but:
http://jedkunz.googlepages.com/tombstonespages
The design discussion is on the HTGuide forum, and I believe there are listening impressions on the PE Dayton DIY pages.
Jed came up with a better hybrid solution. He removed the DXT voice coil and attached it to the motor of the H1212. They were on display at the recent diyDayton.
Jed's Tombstones
Madisound is the source.
I hope DXT voice coils become available as replacements so I can do the same thing.
I've never seen proof-only speculation-that a waveguide loaded soft dome would suffer from back pressure within the guide. The suggestion is that a metal dome is necessary to avoid that.
Jed's Tombstones
Hi Ed
I’m looking for 93 dB sensitivity (to use with a tube amp).
While the DXT waveguide on the H1212 motor improves the low end harmonic distortion profile, etc, do you know/ what are the gains in sensitivity?
I'd guess adding the waveguides isn’t hard, wonder where Jed gets them?
- Seas waveguide tweeter?
