Searching simple BTL approach
Hello everybody
i'm searching for the simpliest possible btl approach. i thought of just adding a second VAS and output stage to an existing amplifier design's differential amp non-inverting output. would that be possible? what feedback would be necessary? or is there an even simpler possibility?
i hope you can help me!
unbalanced input to bridge output. so i can use one long-tail-pair as the input, feeding two seperate VAS + output stage, one on the inverting output and one on the non-inverting output of the long-tail-pair? if so, do i have to feed the output of the second VAS + output stage back to the LTP and how do i calculate it?
if it's not clear what i mean i could make a schematic...
hello.
something like this...........
the opamp is a symbol for a (inverting) vas+output stage.
this is only a suggestion on principle...........do not know how this sounds and so on...........
greetings...........
würde die sache natürlich einfacher machen, aber ich glaube wir halten das ganze auf englisch, auch wenn mein englisch zu wünschen übrig lässt :D
i drew two possibilities of feedback. i used quasi-complementary output so i don't have to adjust the schematic later, because i will use them in the final amplifier.
the first file shows local feedback over the vas and the output stage, the latter shows global feedback
  • woofer_lfb.pdf
hallo.
there is a suggestion for a little adaptation of the output stage.
the (little,sorry) picture shows the typical design of many wellknown outputs like naim 200 and so on...........
grüsse............
