Searching for toroid, 2x70V seccondary...
I need a toroid with primary winding 220V and seccondary winding of 2x70V, to reach 100V DC. VA-rating should be >800VA. Any ideas where to look?
The closest I have found is 65V and 110V, nothing inbetween.
Alternative I could need some guidance how to reduce voltage from 155V DC to 100V DC using passive components or step-down regulators.
Best regards, Calle....
have you considered adding extra turns to generate the extra 5Vac in each winding?
The wire in a 800VA 65Vac will be sized to pass 6.15Aac continuously.
If you add extra turns using the same diameter wire then you get 70Vac @ 6.15Aac, well not quite, becasue that would imply a higher VA of 861VA. It would be reasonable to assume that the modified winding could safely achieve a VA rating about half way in between say about 830VA.
It's relatively easy to remove the outer insulation and add the couple of dozen turns required. Then carefully rewrap the insulation.
BTW,
what is the mains voltage specification for your chosen transformers? are they really 220Vac or 230Vac?
What is your normal mains supply voltage? How much does it vary hour to hour or season to season?
paulb said:
You could get a custom one. Why not just use the 2x65V?
Yes there is allways custom ones, but my guess is that it would be even more expensive....
BTW,
It could be a solution to modify a excisting one. But it would be more easy to buya premade one 🙂
The mains in Sweden is nowdays 230Vac but I, and allmost everyone else still say 220Vac from old habbit. The voltage usually stays near 230Vac with a +- of about 5Vac.
