searching for schematics of Behringer PMP1000
Hello.
Can someone help me to get schematics for Behringer pmp-1000?
It is a powered mixer with a blown switch mode power supply.
Shorted mosfets , blown smt resistors and an ic wich I can't read what type it is ( 16 DIP) because it exploded.
Can someone please provide me the schematics
Please send it to forum-user@telfort.nl
It will be very helpfull
Thanks in advance
Hello JvdV,
I have an service manual of the PMH-1000 for you. As far is i know is this the same as the PMP-1000. Just click the link below and choose "free-user", wait 45 seconds and the download will started. The output voltages that powers the endstage are 55Volts positive and 55Volts negative. I've just bought an new power supply (Behringer SPS400) at PMS Electronics in Germany. Good luck with repairing you're powermixer.
Behringer PMH-1000
Behringer PMH and PMP power amp is different
Hi. I downloaded this PMH manual, and the DPA300 power amp board differs quite a bit against the board in my PMP1000 which is a DPA300-2.
Some of the caps are different values, as well as resistors. The fets are the same...but the diagram is very diffferent than the PMP1000.
Does anyone specifically have the PMP1000 shematics they can send me?
saranden@yahoo.co.uk
Grateful
PMP1000
Like Saranden in June of 2010 I need schematics for a PMP1000. Has anyone seen any information about the DPA300-2 power amp only lasting a few hours and then blowing out again? If so, is there a modification to help prevent this problem?
If the amp blows right up again, it is because it was never completely repaired in the first place. There is nothing inherently self-destructive in these amps. Always check the triac crowbars on the speaker jack boards for failures after an amp has blown.
You can find the schematics for the PMH1000 at Elektrotanya. They have three different files on it. That should be the same, at least as far as the power amp goes. I believe the differences in the two models are cosmetic. My PMH1000 file has teh DPA300-2 in it.
The low pass filter on the output of my DPA300-2 amplifier capacitors were burned so bad they were beyond recognition. On the PMH schematic they are designated C11, C20 and C32 on the schematic. However they are C13, C22 and C34 on the board. The same is true of output B. My question is what kind of capacitors are these and what is the voltage rating for them? Would you happen to know?
Thanks, Tom
Hello.
Thanks in advance
Hello, where did you go to download a service manual for the Behringer PMP1000?
Thank you,
Ddblbogey6
