I just plugged in my new speakers for the first time (They're lovely!) and cranked them with some nice, bass-heavy trance, only to discover that there is an air leak someplace, and it's causing the box members to resonate in a most horrible manner... think of pieces of plywood vibrating against each other with every bass note... UGH IT'S HORRIBLE I HATE IT AND I'M TEMPTED TO TAKE A HAMMER TO THE BOX!! HELP ME!!!
So, um, how would you guys reccomend tracking down the air leak and suppressing it?
Run a large sine wave at a pretty low frequency. You can then use wetted lips moved around close to all the cabinet junctions to locate the leak. If you're inhibited about using wet lips, a stethoscope or something improvised like one will also work.
(I'm a U grad, BTW)
(I'm a U grad, BTW)
Wet lips?
What are wet lips? I'm not really worried about damaging anything... these are very sturdy boxes...
How about "remove the largest driver, stick your arm in with a small tube of silicone caulk and add a "fillet" (more caulk) to all the joints you can reach."
SY- Dated a girl while at UTE, she didn't like wet lips either, come to think of it, prolly wouldn't say the work "caulk" either... A "Tri-Delt" as I recall....
Came away from the U with a whole pile of weird experiences, and fond memories of a certain Java goddess (who, I think, is still in the CS dept). When were you there?
This will date me...'69-70.
Wierd experiences indeed. I ran away. But godesses certainly to be seen. It wasn't just "Gravity Hill" that seemed to be upside down for this Clarkson hockey fan. :^)
*SIGH*
Okay I'm lost. This thread is now officially useless.
I did get the leak fixed; it was just a matter of adding extra screws to the removeable face of the box, and making a sort of gasket out of craft foam, that makes a very nice airtight seal when the box is screwed shut.
- Searching for Leaks (aka !@#$)
