Greetings.
I'm pretty sure I've seen several such DACs, but now I just can't find them. Could someone please throw a link at me?
Thanks in advance.
Thanks in advance.
I forgot there is an error in my schematic. The filter pin is on the wrong node of the passives. It's easy to see where it should go.
Thank you both very much!
theAnonymous1, how's the sound? My impression was passive I/U is not a good choice for PCM179x. What are the requirements to the subsequent amplifier?
Oh, and how can I adjust for twice a lower output current (I have a prototype board with PCM1798)? Should I double the 420 Ohm resistors? I'm quite a noob in electronics...
Sound is excellent IMO, but I used an I/V stage similar to the one in the link ktta posted. When I made the schematic I was still undecided on what to do for I/V.
I'm sure there are lots of optimisations that can be done to my circuit, but where do they end once you start? You eventually end up with a cutting board size PCB with hundreds of components. I like to keep things simple. 😉
Well, since I'm not a fanatic, for me they end once they stop sound better🙂I'm sure there are lots of optimisations that can be done to my circuit, but where do they end once you start?
Me too, thanks again for the design!I like to keep things simple.
P.S. So, should I double the I/U ohms for twice a lower current? Or am I understanding its operation wrong?
P.P.S. Don't you, by any chance, have a PCB layout for this? I've tried to make a layout for just a bit bigger scheme, and the process make me feel like the dumbest person in the world. I guess topological cretinism is my diagnosis.
The higher the R value the higher the output voltage (and noise) will be, and the lower the current draw on the DAC outputs.
If you base your design around my schematic, I would patch in the I/V LPF stage from the second link ktta posted.
Sorry, I'm horrible at math so you will need to figure out what R value is best for the 4mA p-p of the PCM1798.
So I actually understood it correctly, for once!The higher the R value the higher the output voltage (and noise) will be, and the lower the current draw on the DAC outputs.
As far as I already have a half-assempled prototype board, I guess I'll experiment with I/U.
- Digital Source
- Searching for a simple DAC schematics - DIR9001+PCM1794
