Searching for a simple DAC schematics - DIR9001+PCM1794
Thank you both very much!
theAnonymous1, how's the sound? My impression was passive I/U is not a good choice for PCM179x. What are the requirements to the subsequent amplifier?
Oh, and how can I adjust for twice a lower output current (I have a prototype board with PCM1798)? Should I double the 420 Ohm resistors? I'm quite a noob in electronics...
Sound is excellent IMO, but I used an I/V stage similar to the one in the link ktta posted. When I made the schematic I was still undecided on what to do for I/V.
I'm sure there are lots of optimisations that can be done to my circuit, but where do they end once you start? You eventually end up with a cutting board size PCB with hundreds of components. I like to keep things simple. 😉
Well, since I'm not a fanatic, for me they end once they stop sound better🙂
Me too, thanks again for the design!
P.S. So, should I double the I/U ohms for twice a lower current? Or am I understanding its operation wrong?
P.P.S. Don't you, by any chance, have a PCB layout for this? I've tried to make a layout for just a bit bigger scheme, and the process make me feel like the dumbest person in the world. I guess topological cretinism is my diagnosis.
The higher the R value the higher the output voltage (and noise) will be, and the lower the current draw on the DAC outputs.
If you base your design around my schematic, I would patch in the I/V LPF stage from the second link ktta posted.
Sorry, I'm horrible at math so you will need to figure out what R value is best for the 4mA p-p of the PCM1798.
