Hi ! I want to build a "copy" of The voice of the theater but without the budget to buy GPA copycat of Altec.
Anybody here found a 12-15 inch woofer how sounds like Altec pro typical sound ?
I search a low budget woofer with very high spl
extremely stiff and thin paper cone
with detailed midrange sound that gives you goosebumps.
FLH configuration
I even had it made by a company on alibaba company a copy of woofer with the spec and all data sheet, but the result was terrible and I put that to the garbage !
thanks in advance ! 🙂
nicK
FLH configuration
nicK
Hi Nick,I search a low budget woofer with very high spl
BLH or folded horn configuration
One needs to be reasonable.
Low budget, high SPL - Yes to a point.
Stiff and thin with paper is not easy. Altec loved their paper.
Detailed midrange - like you get from some Altec drivers, okay
BLH - I'm not sure Altec did that. They were all about PA. FLH and BR combo was their mantra.
You are going to get what you pay for. I have used Selenium (now owned by JBL) in my Altec cabinets but they are not cheap.
Maybe you need some mid priced Eminence. Have you looked at them? I agree. The drivers you see from these budget houses are just that. Never going to satisfy.
I use Electrovoice EVM15L's in my midbass horns, which seem to model similar to the 515's.
If you look at the Klipsch forums there is a lot of good reports about the Eminence 15c woofer as an alternative to the klipsch woofer in the La Scala midbass horn. (have a look at the Peavey FH1 w-bin as well)
Rob.
Rob.
