I guess you are looking for an SE transformer...
Jack Elliano at Electraprint will wind you one (I am quoting dsavitsk here... ), and according to dsavitsk they also sound very good. Lundahls should be worth their money also...
I am currently using Hammond 119DA line matching transformers in my Aikido parafeed headphone amp. They really surprised me in how good they sound for the money.
The Sowter seems to have a good reputation. It is for AC coupled only, so for parallel feed.
As for single-ended see Figure 3 on this page...
http://headwize.com/projects/showfile.php?file=ciuff4_prj.htm
Absolutely not true in my experience if the cct is designed correctly.bigdogwang said:Some user say about Lundahl: high frequency is good, but low frequency is so so.
I have used quite a bit of Lundahl iron.
I research Lundahl web, there are 2 parts, LL1630 and LL1680.
How are their different? Which is better for 5842 or 6SN7 ?
http://www.lundahl.se/pdfs/datash/1630.pdf
http://www.lundahl.se/pdfs/datash/1680.pdf
Even though this is a 7 year old thread, I found something relevant to add. I hadn't seen this before, maybe it's new, but Edcor makes an interesting looking version of its 10 watt single-ended OPT with an 8k primary and 50 ohm secondary. That should be good for many headphones.
https://www.edcorusa.com/xse10-50-8k
I have no idea what the primary inductance is, though. The frequency response is claimed to be down -1dB at 70Hz. The specs for the version with 8 ohm secondary says primary DCR is 147 ohms and inductance is 4H. I don't see how that adds up, but there you have it. FYI, FWIW, YMMV, and so on.
- Headphone Systems
- Search good performance HEADPHONE TRANSFORMER
