Search for large sized analog VU-meters
If you have the circuit, all you need is any old meter of the right size/ formfactor and the 'meter' software from Jim Tonne. You design the new scale on your PC then print it to a regular printer.
I used it and printing on semi-glossy photo paper gives you a very professional scale.
MeterBasic is free but Meter cost only a little and is very flexible.
Supports log scales and other non-linear scales, should work great for Vu meter scales.
jan didden
Do you already have a housing for them? Where do you plan to fit them ?
I was going to suggest to buy a defective Technics and use the housing and vu-meters. If you do not need the amp you could fit anything else in the housing... I own a Technics amp with vu-meters and i love them.
no housing yet, well, apart from an idea about the casing design 🙄
Not sure if it will be a mono-amp or a stereo-amp.
Wonder if the large McIntosh 2kW panel meter is from Hoyt?
I´d like something similar large and with a similar long pointer.
Hoyt, they at least offer smaller meters with the EL-film display lighting the McIs also make use of.
jauu
Calvin
Beware the below are not specific VU meters, but just analogue meters. I did not have a ruler at hand, so pen is for size comparison (papermate flexigrip)
Beware the one to the left is bigger (~6") than the middle one (~5", which still has its case, so is a lot closer to the lens)
Anything you could use? (You did say "large"...) Beware shipping is killing...
(somehow above link doesn't work for me, only shows thumbnail in new window, so below the link to imageshack's big picture)
http://img804.imageshack.us/img804/347/imag1521.jpg
