This will be my first speaker box build for a pair of SEAS Exotic drivers and I was hoping you all could help me with a few questions.
Does the box need to be square and does the shape matter in a sealed enclosure? SEAS recommends 2.1 cubic feet (60L) and if a rectangle is acceptable it would have the same net volume without a cube on a stand.
Would 3/4" MDF with internal bracing and dampening materials be enough for an acoustic suspension enclosure? If so, there are premade sub boxes or any car audio shop can build a custom MDF sealed box.
Does anyone have any experience or recommendations on enclosures for this build? I remember reading Mr. Pass has a pair but if anyone can point me in the right direction with links/ threads/ designs etc I would appreciate it.
Seems no one wants to contribute - I will help where I can.
The shape of the box can be pretty-much anything, providing the volume stays the same. However, this driver reportedly sounds pretty average in tall slim enclosure. Personally, I would go for a wider than usual front baffle with the box proportioned using the golden ratio. Wikipedia and google it “golden ratio”.
I can't really advise on materials and avail cabs. MDF should be okay for a sealed enclosure, provided it is well braced etc.
Personally, I will probably be going for an aperiodic enclosure in void-free ply for these drivers. I need to do some research though. Yes, I have finally settled for these drivers, despite their efficiency being lower than I would like... hopefully they will be efficient enough.
Best of fortune
Best of fortune
Thanks for the reply. There seems to be little interest in these drivers and I was hoping for more experiences from people. It's hard to take the plung on them given the price and what little people have posted.
Yes, I understand what you mean. Interesting that Feastrex drivers get sooo much coverage when, according to someone whose views are worth some weight, the SEAS may present music more to many folks' liking than the lower-rung Feastrex drivers. Feastrex does have the art / collectible cache and the geurilla marketing thing going on, which helps of course 😉 I would love a pair, but will wait until I can justify some D9e series drivers. There IS something about Japanese artistry.
In the near future it will likely be SEAS for me - kinda cool that not too many folks have jumped on 'em and that the cabs are an easy build. Tho, higher eff would be nice - I now have to decide how to get a little more amp power whilst letting the music flow in a direct, expressive, nuanced, textural, yet dynamic manner. Ah, the challenges.
Cheers
Cheers
fullrangers somehow lacking of
good bass and up highs...
mostly all of them
but they have good middle
and without crossover, at critical F places...
So Your Idea is good to put the unit into
sealed cabinet,
and
make the system open for developing
for instance adding ribbon tweeter as top highs,
and sub for low
on that way You avoiding complex crossovers at the mid read FR,
still even without, You will have more clear,and fast sound with
sealed but good one
DO NOT USE MDF, highly resonant,
use plywood natural material,
maybe You will have a little bit less bass
but it will be more clear and direct
not like woof, or time to time resosonating like the most...
The shape is the best to be circular like a big ball, spherical...
but that is hard to built...
so somehow try to balance between the complex shape and feasibility...
Tip
simple barrel without parallel bases...
your driver is good deserves something like more then mediocre...
try to consult some other sofware for detemining the
volume of the cabinet.
Do not take factory datas like as is...
cheers
mostly all of them
sealed cabinet,
and
and sub for low
sealed but good one
Tip
cheers
A barrel shape is interesting. I had thought of a clyindrical shape but either is a little above my current skill set using wood.
johnsonad said:Does anyone have any experience or recommendations on enclosures for this build? I remember reading Mr. Pass has a pair but if anyone can point me in the right direction with links/ threads/ designs etc I would appreciate it.
I have a pair of these and they are truly excellent. Overall they don't really belong in the
Lowther/Feastrex camp. I think of them more as super versions of the Jordan J92s
(which I like a lot), with the ability to handle higher power, more linear excursion, and of
course a larger cone surface to take a larger bite at low frequencies.
They do not have the sensitivity of the Lowther/Feastrex, and want more power and
damping than the typical SET, which does not make them the darling of the traditional
full range camp.
Seas recommends a sealed enclosure for them, but I am still farting around with
open baffles. They will shortly go into some 4' X 6' flat OB's, and I'll have some
interesting information.
Hi Nelson. Thanks for taking the time to post here – your comments, here and elsewhere, are always weighted highly in my considerations. I think of them as more efficent and more advanced Fostex FxxxA series drivers...
Your thoughts generally appear to reflect those of the person I referred to in a previous post. He prefers 10W+ to drive his, tho he did state that the more dynamic SETs of 3W (for near-field listening) or 5W (in smaller rooms) are adequate. Thankfully, the SEAS present music nicely at lower volume levels; nice to know they are less restricted at higher levels than many wide-rangers tho.
Interestingly – and what I think has sold me on them – is that they do PRaT (I feel like a prat even using the term!) across the freq range really well; I guess that is down to sealed loading, the usual wide-range virtues, and decent displacement all combined in one neat little package. I find PRaT (eek!) is a significant factor in communicating the emotional message of music… it involves me. Hell, I can’t imagine grooving to De Phazz (Days of Twang on now) played back on a dull system.
I look forward to your OB trial - I had thought of that too, tho will have to wait until I move into larger place.
Okay, nuff ranting. Thanks again Nelson.
Why would they be like 'more advanced' Fostex F200a drivers? They don't have all that much in common as far as I can see, other than being 8in drivers with alnico motors. From the base parameters, we see the Fostex has no whizzer cone, less Xmax, more motor power & a higher nominal impedance. It's less sensitive, but probably not by quite as much as Seas claim. They're different, certainly, but that's about all.
I also looked at these when they first came out... also on the pricey side but it has lots of company beyond that level, i.e., Lowther, Aer, Feastrex. There is now a user guide available in addition to the spec sheet which has additional information and some recommendations.
http://madisound.com/pdf/ExoticUserGuide2.pdf
I guess anyone looking at this driver has probably found it but attached the link just in case. I would probably grab a pair of Fostex F200A before these, based on the F120A performance.
Still, I'm interested to hear what Nelson thinks once he has more time to play.
Regards, KM
Regards, KM
Thanks for posting Mr. Pass. I was hoping to draw you out on these again, and look forward to reading about your OB experience with them but don't personnally have the room or WAF for OB at the moment. Now I just need to get off my butt and get the boxes built. As far as 4 ohm vs. 8 ohm drivers what are peoples experiences one way or another? My amps can handle a 4 ohm load just fine.
rcdaniel said:Hell, I can’t imagine grooving to De Phazz (Days of Twang on now) played back on a dull system.
I love De Phazz.
I would like to hear the full range seas compared to the coax seas
http://www.madisound.com/catalog/product_info.php?cPath=45_238_347&products_id=1353
Apologies - poor semantics on my part. In hastily composing that abominable post I chose my words unwisely. I have let myself, all wide-range driver aficionados, and my country down. I am ashamed 🙁
I was trying to express - ever so insufficiently - that the SEAS driver, by one experienced builder's accounts, presents music in a manner considered more stisfying than the Fostex; the drivers are a more recent, well thought out, and in some ways innovative design; and the drivers may also appeal to a similar type of DIYer due to use of (relatively) simple cabinets, lower efficiency than many wide-banders etc.
Perhaps I was writing in conceptual and contextual terms, rather than 'technical' terms; neverless misleading. I trust this clarifies my post.
I love De Phazz.
Nelson, yeah, its great, interesting, fun (mostly) music that just makes me wanna move (badly) 😉
Hello guys!
I have been playing on Lowther DX3 for a couple of years now, and recently changed to Seas Exotic in my speakers. Probably not going back.
My speakers has about 80 l volum and that works just fine.
Lowther is more "right in the face", but the Seas is more relaxed, playing with deeper bas, and have a wonderful mid and top, with plenty of information. It just sounds more right. Not missing anything at all.
I'll recommend anyone to try this speaker (not cheap, but worth it)
Here's a couple of pics:
With Lowther:
With Seas Exotic:
Lars
With Lowther:
With Seas Exotic:
Lars
Wow, that's great. I have a pair of these drivers and have enjoyed
them in open baffles, where they also do a great job.
If I'm not mistaken, you will see them in coverage of RMAF, where
they are on display in sealed enclosures (for which they were
originally designed).
Thanks Mr Pass!
I'm using a pair of monoblocks, push/pull 300 B's , 25W to drive them. Maybe I should try a good transistor amp? I've heard that a combination of a valve pre and transistor amp is a often a good match.
Any suggestion of a good amp to go with Conrad Johnson PV 14?
If of any interest, here's the tread of building my speakers
http://www.diyaudio.com/forums/showthread.php?s=&postid=902565#post902565
regards
Lars
regards
Lars
- Full Range
- Sealed enclosure for SEAS Exotic
