SE Output Primary Impedence
Hello all,
I have been re-reading an article in the April 2004 issue of Audio Express titles "Easy-to-Build, Low-Cost SE Amp". The subject of the article uses 12L6 output tubes to yield about 3.5 watts.
In researching these tubes, the output power is stated for a 4000 ohm load. I assume that the 4000 ohm load would be the impedance of the output transformer primary.
If I was to parallel a second output tube in order to obtain more power, would I need to halve the transformer primary impedance?
Thank you.
Mike L.
getting rid of DC
hello,
I've been to an audio-show and it gave me some stuff to think about.
There was an philosophy about getting rid of the d.c. in SE output transformers.....
This is done by putting a coil in the anode line....At the output of the tube you place a capacitor that goes to the output-transformer....
Now you don't have the dc in the outputtransformer...
(in depth info will be available on www.mennovanderveen.nl)
Will this sound nice??? i think so, what are your ideas about this????
Re: getting rid of DC
This is known as choke-loaded shunt feed, or more commonly known nowadays, as parafeed. You might be able to dig up a few more references and opinion about the "sound" of this type of circuit by searching for "parafeed"
