How much should I read into the wattage ratings given by transformer manucturers?
I want to drive an output stage using a single ended EL34 (6CA7) pentode, a 25 watt tube. I was having a look on Hammond's site earlier and they have something that looks close to what is needed -
1627SE
But they list it's rating as being 25 watts. I will be running the EL34 quite hard, into Class AB. This output stage is for a lead guitar, so tube distortion is actually beneficial. I should really be more specific and say peak-peak clipping, not the roll-off distortion of an OPT going into saturation.
Do you think Hammond mean it will genuinely take 25 watts, or that it will just take 24.999 watts, after which point it melts?
Also, I noticed something odd in a schematic for a guitar amplifier. Rather than bias the power tube, the designer just added a resistance to the cathode of the power tube, set to around the maximum amount of current he wanted to flow through the tube, which was an EL84. Why would this be, and what are the implications of it? If this is fine to do, why not do it for every other stage, after the initial stage, in a common cathode amplifier?
In the preamp, he biases two 12AX7's, so there are four stages. The first is only to lift the guitar's signal to line level. The next stage acts as a volume control, but will begin distorting with hard playing and high volumes. The next is designed to go much futher into distortion, I would guess this would be marked as the 'gain' on the front of the amp.
So he's used 3 stages of a possible 4 and produced a great deal of gain. He then puts the signal thru a cathode follower. Connected to this is a tone stack, a collection of three band pass filters. Would there be any reason for using a cathode follower at this point? It's output resistance for instance? I'm probably making some really dumb mistake, but I don't think I can see any negative feedback being used in this stage.
I was looking at the earlier stages and measured the signal from my guitar while I was playing. I found there was ~100 - 500mv depending on how hard I played, but it averaged at around 300mv. The first stage produces a gain of around 58, which means the singal entering the second stage is around 17.4V right?
If my 12AX7 stage saturates at 0V and cut's off at -2.2V, this means that the signal coming from the second stage could over 100V if the of this stage is roughly the same as the last?
1627SE
Sorry to disappoint, but the EL34 in SE will only give about 10 watts.
As discussed recently, the practical max for class A1 is 25% of anode dissapation. You mention AB, but SE can only run in class A.
It might be possible to push a bit more, but it would mean rather complex drive and power supply circuitry. If you need more, it's simpler to use a pair.
How much headroom transformers give their products varies. I'd happily run a Sowter transformer at, or just beyond it's rated power, and expect good results. I don't know the quality of Hammond. You can tell a fair amount by just comparing weight and dimensions. There can be small variations due to differing materials, but the laws of physics remain the same 😉
SE is particularly sensitive to transformer ratings. Too small a transformer will spoil the LF response, causing level deficiency and distortion.
Output transformer specifications are a very variable quantity, and frequently need to be taken with a pinch of salt. Maximum power capability is inversely proportional to frequency and distortion, so any transformer will distort if you drive it hard enough or low enough. Worse, inadequate primary inductance causes the valve to distort as it has to provide current in addition to intentional load current. The way to avoid this is to specify the primary inductance to have a reactance equal to the load resistance at the lowest frequency of interest. Thus, the Williamson specified 100H for a 10ka-a load, making it good down to 16Hz. Achieving this sort of inductance and a sensible flux density in the core usually requires a large core, making for a big, heavy transformer as dhaen has already pointed out.
An electric guitar is a very boring instrument played through a Hi-Fi amplifier. It's the guitar amplifier's distortion that gives the entire instrument its character. Normal rules of Hi-Fi design need not apply.
It's not really a disappointment, rather a slight benefit. I specifically chose think about SE designs as 50 watt PP design's are far too loud to run them all out, especially around the home.
My amp is a 100 watt half stack. I bought this not quite knowing the meaning of what loud was. I have had complaints from neighbours without it ever reaching 5 on it's volume. Above 5, it's unrealistic. The window panes shake, my ears feel like they're about to bleed and the police are ready to visit.
At the moment, my family complain if it ever goes above 2. So power tube distortion is never going to happen. In fact, the amp barely even seems to be alive most of the time. Which is a real annoyance for me.
You mention AB, but SE can only run in class A. As discussed recently, the practical max for class A1 is 25% of anode dissapation.
I reversed your points to help me understand them. Is this due to the quiescent current continuously heating the anode even while no signal is being amplified? 10W is ~4W over 25% isn't it? I guess this is because it's not true class A1?
I may end up going that way. I was reading about how SE amplifiers have problems with OPT's causing distortion, but, similarly, a while ago I was reading about how it can be very easy for a PP's phase splitter to distort the signal. So I've started to see it as a trade off. With a PP design, I would need to start using phase splitters, while an SE leaves me with the OPT to deal with.
I also noticed a lot of high end systems seem to believe the phase splitter causes more distortion of the signal than the effects of the OPT in an SE amp.
I read that a couple of manufacturers use ?pinstripped? laminations with mu-metal every other iron lamination to try and remove none linear coupling. I don't know how true this is or how widely it's used. Mu-metal has a very high permeativity, so it should begin coupling earlier and then saturate soon after right? Which would help couple the lower frequencies?
Unless you like clean guitar's I guess! But I see what you mean. At the same time, there are certain forms of distortion that I don't want to hear. A lot of amplifiers have a very rounded off sound to them. While they are clipping the signal, they are also smoothing off some parts dependant on their frequency. So every guitar starts to sound the same as the rest, and looses it's harmonic signature.
The simplest example I can think of is rectifiers. Mesa Boogie often use tube based rectifiers in their lead amplifiers. They sound okay to me, but they seem to mask the real dynamics of the player in voltage rise times. Where as Marshall use almost only solid state rectifiers, which sounds much more upfront. If you compare Metallica to Van Halen, that's a good example of what I mean! 😀
I don't mind tube's clipping the signal, but such frequency dependant rounding off I dislike.
Hammond 1627s
I've used Hammond 1627s in an SE 6L6, and boy are they big. I think they are 5 Kg each. In this case I'd expect that if they are advertised as handling 25 W, they will - advertising optimism aside.
I am not a guitarist, but I was under the impression that trafos for guitar use were often intentionally undersized - the resulting distortion being a major component of amp "tone".
If you are looking for that big fuzzy blues sound, I'd think an over-qualifed transformer is not what you want. Playing electrified acoustic might be alright.
And simply from a logistical standpoint - Do you want to lug an amp w/ a 5 Kilo OPT around?
On preview,
>I don't mind tube's clipping the signal, but such frequency >dependant rounding off I dislike.
The interwinding capacitance of the trafo is going to be an issue at HF. A bigger winding will have more capacitance, and more HF rounding.
Have you looked at the SE guitar amps that Wavelength Audio builds? http://www.guitar-engines.com/index.html Gordon Rankin may have some ideas he'd be willing to share.
Andy N
On preview,
Andy N
For some players it is, but I don't particularly like it. It's described as squish, or sag. Like rectifiers, to me it sound's okay, but I'd rather loose the slight rounding if it allows me to hear how my guitar it's self sounds - to let some more of the harmonics come through.
The players who use tube amps always accuse the ones using the newest digital modelling amps of playing with a computer. Not quite so directly, but it's behind almost everything they say towards each other.
But in a similar way, heavily saturated tube amplifiers seem to be as equally disconnected to me. It feels more like you're playing a note, and the amplifier is making a corresponding sound, not amplifying what you've played.
The newest bands on TV are really bad for using this style of playing. They not only use super squishy amplifiers, but then use horrible amounts of clipping to help cover over any mistakes and make it sound like any modern, society hating band should sound.
I don't like fully distorted, and I don't particularly like clean sounds. So I want to kind of going for the middle on this one.
Actually, it's not so bad. I used to play with a few friends. The drummer always assumed that unless there was going to be a drum set already there, whenever we played we'd be at his house.
It's not the amplifier it's self that's a pain in the *** to move, it's the 3ft tall, 50kg speaker cabinet that goes with it. Along with the associated miles of cabling and adaptors.
I got sick and tired of the 'I have a drum set so I can't move it' excuses and gave up dragging it round there. It's more of a physical volume problem, since most 4 x 12 cabinets won't fit in a car very easily. He also had a very small set of stairs up to where we practiced, the cabinet barely made the corner in them.
It's exactly like that say. These guys I played with are two of the best friends I know. Yet the minute we started playing, all the issues come out and people start getting very angry, very very quickly. It took me about two or three times playing with these guys to get so annoyed that I didn't want to continue.
I'll check it out. I know that the highest fundamental frequencies of a lead guitar are around 1 - 1.5kHz depending on which tuning you decide to use. So I would expect the third harmonics to be around 12kHz, which is where I saw such SE OPT's from Hammond beginning to have problems with overshoot and distortion.
The good thing is that the highest notes of a guitar are very rarely the majority of a tune. Almost all verse & chorus riffs are around the low E6 string, which has an open fundamental frequency of ~100Hz, again, tuning dependant. SE still has a chance!
Awww... I feel sorry for it now. 🙂
eeka chu said:The players who use tube amps always accuse the ones using the newest digital modelling amps of playing with a computer.
My buddy plays through a POD, into a Mesa Boogie MKIIc. He loves it; I'd rather build amps.
Looks like you're registered in the UK, so I'm not sure if this is a practical idea, but here goes: You might look at Electra-print transformers. Jack Elliano, the owner, loves to talk at length about the various aspects of transformer design. He does custom work, his prices are reasonable and his quality is great. The money invested in an hour-long phone talk with Jack wouldn't be wasted. Hs is in Las Vegas, which is GMT-8 time I think. Plus the dollar is weak now; never been a better time to buy. I'm just a happy customer, no affiliation.
Do you feel comfortable with the distinction between 'traditional' Direct Feed and the 'old-is-new-again' Parallel Feed? (aka parafeed, or shunt feed) I get the feeling that you'd like the parafeed topology. Gordon Rankin has a good write-up here: http://www.guitar-engines.com/ampspf.html
The key point is that parafeed allows you to use the exotic high-permeability metals in the OPT, since they are relieved of the job of passing DC current. DC saturates the exotic stuff, rendering it useless. Like you've mentioned, the hi-perm stuff is desireable because it works better on the low end. Plus you can wind on a smaller core, allowing for lower interwinding capacitance = better high end. Win/win, if you can afford it & are happy with under 10W or so.🙂
As a point of reference, I listen to a homebrew Single-Ended parafeed 2A3 amp with a Magnequest cobalt OPT (cobalt is ultra hi-perm). 2 watts of wideband low-distortion bliss. You've got me thinking... Someday I've gotta invite my pal to bring one of his pickup equipped acoustic guitars over to play through it.
Cheers, Andy
Bias
Did you get an answer to your question about Bias? The resistor under the cathode?
It's called self-bias. The resistor elevates the voltage of cathode by the desired amount, and the grid is tied to ground via a few-Kohm resistor. The grid is at ground potential, which means that it's negative relative to the cathode, which (voila!) is a biasing difference. It's a nice technique because it obviates the need to build a seperate bias supply, and it automatically adjusts the bias as the tube ages.
The cathode resistor is often bypassed by a largish capacitor, that shunts AC frequencies to ground. It's also a bit of negative feedback (I'm told) which raises gain a smidge. Some people advocate removing that cap; it works both ways, and is a sonic taste issue. I leave 'em in.
Guitar Amps info
Gang & John,
Just a couple of things...
First SET pentodes do work great with guitar amps. I will be releasing a Rob Fetters signature 25W 6550/KT88 amp head/combo soon.
The reason for the smaller output is because the low end is equated to low E or about 80Hz. Going to 20Hz requires much more inductance and therefore more iron. Though less iron is not the way to go as many of these output transformers available for SET guitar amps are too small and require too much feedback.
Ok a word about gain... You will need a ton of gain in a tube guitar amp. Think of it this way... Max input is usually speced at 10mv. The Tone Stack robs between 20-30dB (ouch) and the EL34 for 10W output requires at least 10V's input (assuming 5K load). Ok so you will need at least 90dB of gain or a gain of 30K going to into the EL34.
On gain... 12AX7A into a Tone Stack lucky if you get a gain of 45. As far as a driver stage 12AX 65 and remember the needed feedback usually -3dB. So you really need like a 12AU7 stage with a gain of 10-12 to get enough drive into the EL34 to get it too 10W's.
SET's do sound really great for guitar amps in many ways and sound much larger than their PP counterparts by a factor of 3-4 times.
But that's only my opinion others always welcome!
Gordon
Gang & John,
Gordon
I hate the mathematics and complex physics involved in so much of building electronics well.
At the moment, my main drive to build my own amp is that I'm not happy with what I have at the moment. It's far too loud and now quite detailed enough for me.
I like listening to music, but it's nothing compared to standing in front of the the speakers and knowing it's you making the music!
I started to think about this just before I checked back here. I've never really looked at it, but my initial idea was -
"Hey! Wouldn't it be excellent if I could just drop the DC away from the transformer through some kind of broadband high pass filter!"
When I first saw the idea on Gordan's site, it looked a bit weird, but I understand it fine now.
I'm not so sure of the real world component costs and realities though, as it is mentioned that the idea only becomes realisitically usable under 8W and above 16W.
As soon as you began explaining it I realised what had gone wrong, and it was me not noticing the ground reference resistor connected from the grid to to ground!
Rather than being squashed up close to the tube, it was shunted over, futher away, so from the corner of my eye I must have thought it was a volume control.
Not enough coffee...
Interesting, the particular design in question uses an EL84 in a SE design and suggests a dissipation of 11.7W? 😕 This design definitly doesn't use any special arrangements for it's output.
Some answers I hope
John,
First off thanks... I am Gordon Rankin and Guitar-Engines is my site as well as WavelengthAudio.com
Ok.... Biasing is pretty simple in a pentode take the screen current and the plate current add them up and divide by the bias voltage. So ok lets say run the EL34 at like 75ma, screen proabably like 8ma and bias voltage like -20V. So like 240 ohms for a self bias setup. Determine the watt as follows 83ma*83ma*240. Make sure that the wattage is 2-3 times as much too make sure they last long.
As far as Parallel Feed is concerned here is the way I look at it. If the wattage is below 10W's then it is a good thing and over 25W's it's a good thing. In the middle it's almost better in SET land to do direct feed. It has too do with miminishing returns... See a good 25W output for guitars using direct feed might be about 12-15 pounds. In parallel feed you would have a 12-15 pound choke and an 8 pound output. Above 25W's well the output transformer get's too complicated to design good.
For EL84 I have done both direct and parallel feed. Parallel is better a bit more expensive but what the heck!
Thanks for your interest.
Gordon
John,
Gordon
Hi Gordon!
You mentioned a 10mv input. I'm just curious about this, as I know that the output of my DiMarzio pickups is around 300mv or more.
Is there any benefit to placing the PF capacitor between the end of the OPT and ground compared to placing it between the anode and the OPT?
Re: Guitar Amps info
So with gain requirements similar to an MC phonostage,
how come nobody is building guitar amps with the high-transconductance wonder-tubes that appeared after transistors took over?
I'm thinking of 417A, 437A, 7788, 3A/167, 6C45pi, E55L, etc. Stick a supertex mosfet CCS on top and you're in gain city...
Just Curious. Apologies for the thread-jacking.
Andy
Wavelength said:
(snip) Ok so you will need at least 90dB of gain or a gain of 30K going to into the EL34.
Andy
Phono vs Guitar gain
Andy,
Most guitar amps require 1M input impedance. On the tubes indicated that sometimes means grid current draw. Also the miller effect capacitence created by high transconductance tubes can be a problem with long and sometimes complicated Guitar cabling.
In regards to CCS & Phono.... ahhh try it but in my experience the Zout = Rp means problems with tunning RIAA. Also CCS usually means higher noise unless you regulate or filter out the ying yang.
But of course that is only my opinion. yours maybe different.
Gordon
Andy,
Gordon
Gordon,
Is there a particular method for selecting the choke and capacitor sizes? I mean, in a normal SE output stage, the plate load is set by the reflected impedance of the speakers. In the case of the parafeed, would the plate load not be set by both the choke and OPT?
At first, I started out thinking I might set the bias using LM337's, but the more I look at it, it's just over complicating the design. There is too much difference between the bias voltages to make it a simple thing to implement. And, secondly, given the OPT is such a key part of a SE design, I would prefer to have some kind of current limiting. Self bias it will be I guess! Now to think about the HV to the plates!
Also, I think I may have posted this as you where making a post, but isn't a typical output for a guitar's pickups around 200 - 300mv? Is there any difference in placing the PF cap between the anode and the OPT relative to placing it between the OPT and B-?
Parallel Feed
John,
There are pretty complicated ways of determining the Choke size and associated cap. But really the more inductance the better then experiement with the cap size. For an EL34 say running at 60ma on the plate I would say a 30H/60ma choke and proabably a 2.2uF would be best.
As far as where to put the cap think of it this way... On the plate means that all the signal goes through it. Put it on the ground side and it is merly pulling the transformer to ground AC wise. That of course is over simplification but the best I can do. I always find it better on the ground side.
Gordon
John,
Gordon
Thanks Gordon,
Your ideas with the cap are similar to something Andy mentioned to me earlier. Parafeed doesn't sound so tricky! 🙂
Perhaps you can help me with something else however. I have spent the last hour going through web sites reading about single ended amplifiers. Every site I visit tells me that a single ended amplifier must be Class A. Not one provides any reasoning for it.
Why is this so?
I know for a fact that a number of guitarists have built simple single ended amplifiers and then biased the tubes to dissipate almost their full rated wattage. Surely if a substantial negative field is present on the grid, this will cause the tube to effectively cut off. And if the cathode current comes close to it's maximum, again, the tube will saturate right?
I don't see why the SE topology means that the amplifier may only run in Class A. 😕
I also read a few sites that say that to produce a true Class A amplifier, the plate voltage should be low and the current high. If I remember rightly, it is current cut off that causes AB distortion. I know that Van Halen used to run his amplifier at a low voltage using a variac and rebias it for a higher current to produce more cut off distortion. So that's entirely the opposite of what was said, but it's based on reality. 🙁
Why is this so?
All SET amplifiers are class A
John,
All SET amps are class A it doesn't matter how you do it. Well that is the theoretical in practical terms when the tube approaches clipping they tend to draw more current and go into a class a/b kinda thing.
Best to look at the plat current in maximum terms if you want to get the most out of it.
If you want a simple circuit Parallel Feed take like the Fender Princteon 5F2 (NOT 5F2-A) Narrow Panel Version. Bypass the cathode resistor on the input tube with a 33uF/16V unit. Schematic here....
http://www.ampwares.com/ffg/
Use an MagneQuest BC15 choke 50ma/40H and a MagneQuest EXO45 output with an EL84 and it will sound pretty darn nice. You could if you want take the Priceton circuit with the 6V6 and the above transformers and it would sound nice also. Lacking I think in gain, but still pretty nice.
Gordon
John,
Gordon
Hi Gordon,
Why can an SE stage not be forced into AB? I'm not questioning the logic of it, I just can't figure it out. I haven't built an SE stage before so I'm trying to work from a purely theoretical position, which, as everyone knows, never works in reality! 🙂
Thanks for the ideas. I'm well on the way to getting some final drawings done. I will try Sowter transformers here in the UK for the wound parts, as international shipping can get quite expensive! Sowter Transformers produces a MuMetal series for parafeed, but the maximum stock model they have is 5W, so I'm trying to find out how much more wattage they can get from the particular lamination sizes they use.
I know Magnequest uses Cobalt for their laminations. I think MuMetal is chromium and nickel, just like guitar strings! 😀
AB relies on the opposite device (as in push-pull) taking over. Since you are in Single Ended, you haven't got an "opposite device".Why can an SE stage not be forced into AB?
Furthermore, you cannot bias a cathode biased valve into cutoff. The current just gets smaller and smaller, never reaching zero.
Mumetal is used for very low disortion, the opposite of what you need IMO. I think you will get much closer to the sound you want by choosing a design that has controlled overload characteristics (power supply important) than going for exotic materials.
- Tubes / Valves
- SE OPT's & Biasing
