Hi Folks,
Can anyone know what the purpose/function of my red circuited wiring for this SE OPT Primary at 1K6 / 30W ?
Which circuit and example used for ? Any benefit to the AMP design ?
Good thread here: https://www.diyaudio.com/community/threads/cathode-and-other-types-of-feedback.76541/
PS I removed previous schematic because it was not a very good example.
I guess the text is in your own country's language, isn't it? Then you're most probably the one who knows best what it's meant.Can anyone know what the purpose/function of my red circuited wiring for this SE OPT Primary at 1K6 / 30W ?
Best regards!
A bit harsh?I guess the text is in your own country's language, isn't it? Then you're most probably the one who knows best what it's meant.
Hello Kay, I am not a Japanese but is Hong Kong . I just wanted to seek a SE OPT for the KT 150 then found it , however it showing what different from other general OPT that I know, so I resort from this forum expert😁
Anyway i am happy to have your response, especially Jcalvarez 👍
Some mains benefits of CFB (and NFB in general)
1. Allowing the use of pentode/tetrodes with all their pros
a) Low miller capacitance
b) Higher power output (close to 50% theoretical, I've achieved 45% efficiency)
2. Triode like or better linearity.
3. Higher DF vs power output
To get higher benefits vs %CFB, you should be looking for steeper (high gm) tubes.
Thx 50AE your explain
So any suitable power tube for this SE design ? 6C33 is best candidate? I find this SE OPT is 600ohm also has this CFB wiring
It’s a winding dedicated to negative feedback only with a thin wire not able to be used as secondary connected to a speaker.
You can deduct it by looking at the columns where there are written all impedances (0-6-24 for the ZNF) and from the table below, where its Rdc is declared at 3,8 Ohm.
- Tubes / Valves
- SE OPT Primary at 1K6 what purpose of wiring "ZNF"
