SE OPT 125W 5K to 6 Ohm
For sale Automatic Electric Europe (AE Holland) 5K to 6 Ohm single ended potted pair output transformers.
Good for the following tubes like 833, GU48, 2XGM70,…etc.
Primary (Anode) current: 300mA, Primary DC resistance:110,7 Ohm, Primary inductance: 19.8 Henry.
10-30,000Hz.
Each opt 13,4kg.
Slightly used by me, in very good condition.
AE 4:1 Interstages are also available.
$550 for Opt’s and $120 for step down interstages plus shipment or deliver at the airport.
Spec of the interstages as follows;
4:1 Step down.
10-30,000Hz
I had ordered them to use between 300B and 833 tubes.
Primary current 60mA.
Size in cm: 11x11x11.
Weight:3,8kg each.
