SE amplifier advice..
Hi all,
I am not a newbie DIYer (may be as you already know...). And have made a lot of IC, SS amplifiers, tube buffers-preamps for my ear taste until now. Presently I have a pair of Tang Band W5-1611SA full range speaker with 17lt bass reflex box tuned @52Hz.. And a Pass F5 amplifier feeds them. I must say that I found them very satisfactory at the meaning of analytical/clinical sounding. However I think my soul needs more musical things to listen.. Like a SE tube amplifier..
So, at this time I will need your advices about the choice..
I have a pair of NOS EL34, some 6N6P and some 12AU7s in my drawer.. In fact what I have is not important. But I see a lot of SE applications with EL34 tubes in the internet.
I think just a triode input stage (with SRPP may be) and an EL34 works fine for my needs. However I cannot be sure to select one of these projects..
May you please advice a SE project for me?
And what about the output transformers? Does a HAMMOND 1628SEA suitable for this amp or a cheaper one like;
5K SE AUDIO OUTPUT TRANSFORMER FOR ,KT-88, EL-34 | eBay
Thanks a lot in advance for anykind of helps..😛
Please read through fully. 1.5W was referencing the single-ended triode connected EL84 amp he had listened to. 🙂
This one should provide much more than that. Even the RH84 which is based on a similar design but with EL84 puts out about 4W of power.
EL34 should easily double that. If you use a cathode follower, you can probably drive it into A2 territory too... with even higher power.
🙂 The RH84 was my first tube power amp project. The GU-50 my second one. 🙂
Like you, i had already completed several SS amps (chipamps, Pass F5, Pass BOZ, various MOSFET/BJT amps) before my foray into tubes. You will be surprised how similar tube circuits are and are in fact simpler to grasp.
There a lots of circuits floating out there in cyberspace. Have a look at all of them and decide. Took me 3 months of research and another 3 to get the parts for my first EL84 amp.
You will be surprised how loud 4W or 8W can get you with tube equipment. I guess the 2nd harmonic distortion tends to "fatten" the sound and make it louder than the SS amps. The 8W GU-50 amp seems to beat the F5 easily. I think many of those on this forum have the same experience.
