Screw Terminal for the Korg Nutube B1 Preamp
Does someone have the specs or a digikey number for the blue screw terminal that is not in the parts kit for the B1 preamp but is recommended in the build guide?
I know where to buy parts buI don't know enough yet to distinguish this particular one -- that will work with the PCB board for the potentiometer -- from the the many options out there and need to buy it per the spec or the number.
Bonesthrower
As nobody has come forward ---so far -- could you be a bit more specific ?
As there is one potentiometer in the simple design ---the volume control is this a coupling/shaft addition for it or a grub screw ?
Sorry got it wrong there is another variable control is it that one ?
What you are after is the pin spacing for the RK27 Breakout PCB sold in the DIY store front under PCB > miscPCBs. Maybe a post in the analog source or analog line forum and a post in the Krog B1 thread would get you the answer you seek.
