Screeching & Oscillating Sound from Pre Amp
Hi I am new to the forum.
I have a question in relation to a noise running at about 150HZ from my pre amp. It is on the right channel.
The same noise on the left channel but to a much lesser extent and left channel runs at 110HZ.
It occurs all the time. I have changed tubes and noise still present.
it is unaffected by volume of unit. Meaning notwithstanding volume level the noise remains constant and at the same audible level. It does not increase in volume.
It is present even though nothing is attached to the pre amp.
I have uploaded the actual sound.
I'd be grateful for any suggestions as to what is causing this sound, and how to fix it.
Thank you for all your suggestions. They have been very helpful.
The Pre Amp is housed in a solid (6mm) metal casing. It appears the problem is now solved.
I had the Pre Amp connected to an AC Regenerator which the DAC and AMP were also connected to.
I have connected the Pre Amp (via a surge protector) to the same wall power socket used by AC Regenerator (same line).
The Oscillation noise is now gone.
Still a very slight buz, but I think that is coming from the Tubes (6922 x 2).
Thanks again, I am very grateful for your advice.
