SCR pre-regulator
The PCR series from Soundcraftsman used this topology.
This is essentially the same as sticking a light dimmer on the primary like Carver did in most of his amplifiers.
If you want to make it quieter use a bridge rectifier with a MOSFET inside of it. The triac and scr make noise because they turn on half way through the cycle. With an FET you can have it turn on at the zero crossing and then turn off at any point in the waveform.
If you put a cap of about 1uF per ampere that you are switching, across the drain/source of the fet it will be super quiet. Did this several years ago just messing around on the bench. Make sure you use a choke-input fiiter. Also, if you about a 10k to 47k or so resistor in series with the fet gate it will limit how fast it turns on, so that when it short cct's the cap the discharge current won't be too high. OK for mains frequencies, big no-no for high switching frequencies. This is a really good method of power supply regulation for higher power setups, IMHO.
Thanks Circlotron,
I'll try the resistor approach to reduce on and off slope. I intend to use snubber circuits to dampen oscillation between transformer and rectifier bridge induced by the switching transients. I belive this give similar result as a cap across the FET. Anyway, I'll test both. I'll work out a schematic and post it here.
/Jesper
This is more what I had in mind:
http://164.195.100.11/netacgi/nph-P...,510,679.WKU.&OS=PN/5,510,679&RS=PN/5,510,679
It uses back-to-back FETs or IGBTs, a single device inside a bridge is what I had in mind. Whatever gives the lowest voltage drop for your load current is best.
Remember the reverse diode in the FET is conducting in the back-to-back circuits and has basically the same resistance as the device RDS on specification.
If running 240V line at 20A load an IRFP22N50A would drop 4.6V vs a bridge rectifier loss of 2V or so. An IGBT may be a better choice here.
