I have MJK's free sheets,but I'm nowhere near routine you two obviously have with this......
so -can I direct your attention to one old thread :
http://www.diyaudio.com/forums/showthread.php?postid=919737#post919737
anyway, here is pasted txt :
Anyone willing to solve this case ?
I need measures for tall (not folded) TQWT
I know that overall dimensions are not critical,but vent certainly is;
This is what I measure ,using procedure from JBL Speaker Shop.
Unfortunately,I don't have way to measure Xmax,if needed
TIA
old Scan Speak Alnico driver
21W38
Fs=64Hz
Qms=3.054
Qmc=3.308
vas=20.6L
Cms=0.2508mm/N
Mms=24.66gr
Rms=3.246kg/s
Sd=240.52cm^2
Qes=1.155
Re=3.7E
Bl=5.6537
Qts=0.83
Eff=0.4509%
Spl=88.74db
willing to spend 5 min on that?
I really don't ask for more.............mebbe just for one 8" FR .......
About as good as you're likely to get. I ended up doing something similar. You'll get too much midbass gain with TQWT. You could damp it down of course, but why bother when there's a better alignment. And it's still a tall, slim cabinet.
tnx boyz............
just just just another one.........?
TQWT or something ?
old ,ancient Iskra 8"
F3=57Hz
Cmm=1,3928x10^-3m/N
S=0,0292552m^2
Vas=166.8995L
Bl=3,563Tm
Qms=10,3636
Mmm=2,7669x10^-3kg
Rmm=0,1934 Ns/mRez=3,4E
Lez=0,217mH
Qes=0,537
Qts=0,51
TIA
TQWT or something ?
F3=57Hz
Cmm=1,3928x10^-3m/N
S=0,0292552m^2
Vas=166.8995L
Bl=3,563Tm
Qms=10,3636
Mmm=2,7669x10^-3kg
Lez=0,217mH
Qes=0,537
Qts=0,51
TIA
- scottmoose and gm-humble question
