My budget is $200-$600 total. Thanks.
Test Equipment - New - Refurbished - Used - Test Equipment Connection
You really should look into the sound card solution. Very powerful, does all you want, and more, for less than $ 200.
That also is a cheap way to get experienced with this sort of thing.
If you continue to develop your skills, you can then better decide what you really need/want.
Jan
Jan
The DS1054Z is out now and fully hackable to DS1104Z bandwidth just like the DS1074Z was. It's typically back ordered right now but it's by far the best deal going at this time on a new very capable oscilloscope. Now that DPO technology is becoming commonplace on the budget scopes, finally starting to see a drop in the price of old analog scopes.Hello audiodiyfan,
Maybe you could look that, a little bit up your amount,
but you will have up to date stand alone instrument, not a toy.
Regards.
FRex
Then something like the hantek hdg2002b arbitrary signal generator (hackable to 100Mhz) for around $300-350 for signal synthesis might fit the bill.
This would give you a LOT of functionality for not much more than your budget price.
- Design & Build
- Equipment & Tools
- Scope & Signal Geneartor
