Scope pictures of T class amplifier
Since no one wants to share teh precious Class T scope pix, the shots in this Class D Tutorial vid should give you an idea about what's going on. If you're interested only in Class T pix, please disregard this post. 🙂
2 Hz PWM square wave @ 0:53
Class D Amplifier Tutorial! - YouTube
I don't think the vid shows actual prefilter idle state but...
Test question
If a .2v 2 Hz sine wave causes the square wave to pulse at 2 cycles per second on a Thursday afternoon, then a 0 volt 0 Hz input would cause the square wave to:
a. pulse faster
b. appear static (50% duty cycle)
c. look like someone pressed pause at 0:53.932
d. ____________________
I'm sure I have some old ones somewhere.
Basically it's just a square wave with a variable duty cycle. IIRC, zero volts on the input results in a 50% duty cycle.
Different chips run at somewhat different frequencies. Mostly all in the AM broadcast range, like 600-700Khz.
Pano thank you.All this pictures r like ordinary D class scope shoots.I am just curious what is main difference between D class and T class.....but in detailed description (as much as possible).From what i have found on internet T class has different feedback loop and has high tone frequencies more amplified (easy to make with any D class)....This amplification can fake listener to hear "more detailed" sound easy.It looks like that T class is just a good marketing story and nothing else.If there is anyone who can go deeper and show some more details about T class i will be gratefull to learn something.
Julf and Pano thank you ..... very,very much.This is really help a lot to clarify some things and be clear with what i real and what is just a talk....(i am talking about T class).I will switch dsicussion to Tripath patents list topic.Thank you again.
