Schiit Loki Mini+ in my Neurochrome Preamp project
Would really appreciate an advice on how to best connect a Schiit Loki Mini+ in my Preamp project. As an input selector I will use the Neurochrome Input Selector and I plan to use the Neurochrome Universal Buffer with it. The Loki Mini+ will be integral to my preamp (with removed housing). My question is: should I connect the Loki between the Selector board and the buffer board or should I connect the Loki after the Buffer board output?
Beautiful CAD drawing.
I would opt to have the lowest output impedance and good voltage swing as such I would nestle the Loki tone board in between the Neurochrome Selector Board and Neurochrome Universal Buffer (UB) output board. That way you have unbalanced and balanced outputs you can use from the Neurochrome UB. The Neurochrome UB is audibly transparent.
BTW, I think Tom would enjoy it if you asked this question on his new forum as well.
Best,
Anand.
