I need the schematics and some technical tip I have a carver AV705 5.1 THX power amp, the problem is none of the amps is working it seems that the amp is some sort of sleeping mode ???.🙁
CARVING UP.
Hi Leiade,
Have you tried the Solid State brigade,err...category yet?
Mayb you could mail the Carver company,you probably only have to give them the serial# to get a schematic.
Hope this helps you,
Hi Leiade,
Carver Company
Thank you for your kind interest in my problem I can't find the Carver Company I don't know wich of them I should contact🙁
CARVER
http://www.carveraudio.com/Equipmentrepair.htm
Which gives a link to the following subcontractor:
http://www.sunfire.com/
Where you will at long last find on e-mail address under the "Contact" button at the bottom of the page.
Sure gives you the feeling they care for you,doesn't it?
Good luck,😉
Good luck,😉
