I bought several NOS output transformers a few years ago and would like to build some amps. My electronics experience is limited, but I have built several 300b amps and a 6SN7 based preamps.
I need some help locating a reliable (preferably simple), nice sounding schematic/design. Here are the transformer specs:
4000 primary w/ UL taps
70 Watt max
320 ma (assumed since this is a 12lb+ (5.6kg) transformer.
Any help would be greatly appreciated. Thx!
70 Watt max
Assuming they are PP transformers.......KT88 UL PP
Triode Dick's Bill/Mono Bill/Mono Bill 2
Google Translate
Sgregory's Opus
http://www.diyaudio.com/forums/tubes-valves/161702-opus-5-0-modern-mullard.html
TubeMack's Soloist
http://www.diyaudio.com/forums/tubes-valves/156699-mullard-5-20-kt88-pp-blocks.html
Google Translate
Sgregory's Opus
TubeMack's Soloist
Thanks boywonder. They are indeed PP transformers. I was considering a Mullard type circuit using KT88's or el34. Would a triode connected push-pull parallel circuit using el34's similar to the Marantz 9 be a good match for this transformer?
If your OPTs are PP (i.e. 4K P-2-P) then how about: Le Renard? This design outputs 37W, is a good match for 4K P-2-P, and sounds great, and doesn't require UL to do so.
6BQ6s are like more powerful 6V6s, however, these don't require such high screen voltages, and so aren't really suitable for UL. Forch, they don't require the extra help, and moderate amounts of gNFB are all that's required.
Hello Kevin. I love 300B's, but they're out of my budget range. Do you have any other suggestions? I'm pretty new to DIY, but familiar with safety and layout. Not so much design at this point.30W 300B PP amp?
Thanks Miles. I've never heard of this design. I'll definitely have to research it. Looks like i'll have to research this. I'd prefer designs that others have repeated with success (documentation).If your OPTs are PP (i.e. 4K P-2-P) then how about: Le Renard? This design outputs 37W, is a good match for 4K P-2-P, and sounds great, and doesn't require UL to do so.
I would say KT88/6550 in that case with the option for triode strapping - would result in about 25Wrms output, and sound quite good.
Send me a PM and I will send you a driver design (not to be shared however) you might find interesting, and is not too complex.
- Tubes / Valves
- schematic request for transformer with 4k primary and UL taps
