scanspeak illuminator mid range worth the $$$?
CAUTION:
"If you are going to use 12MU, i'd recommend 8 ohm version. It is somewhat better in distortion than 4 ohm brother. Both measured by HobbyHifi.."
One is measured on DAAS, the other on STEPS (Arta)..
DAAS is far less "charitable" with its results. (..I think it has something to do with the signal in relation to near-field measurements, where STEPS is more sophisticated and works better with near-field non-linear distortion measurements assuming the mic isn't into over-load - presumably removing room-noise better.)
It would be really nice if Ivo could explain these sorts of differences (..the reasons for them).
