Scanspeak 10F/8424g 4"Mids Alternatives??
Hi 🙂 , Im restoring a pair of THIEL CS2 speakers and sadly the VIFA stock ones are Blown. In my research trying to find the replacement for the stock model I got the Scanspeak 10F 8424g as the ideal replacement BUT they are too expensive. My other options are the 8 OHM FaitalPro 4FE32 and 4FE35 for less than half of the SS price.
Datasheet 4FE32: https://faitalpro.com/en/products/LF_Loudspeakers/product_details/datasheet.php?id=401005100
4FE35: https://faitalpro.com/en/products/LF_Loudspeakers/product_details/datasheet.php?id=401005150
Scanspeak 10F 8424g:
https://www.scan-speak.dk/datasheet/pdf/10f-8424g00.pdf
Would they work for as replacement for my Thiel's ??? Is there a better option??
The SS 10F’s are special. You really can’t replace them and get the same sound. Very flat response, very smooth and low distortion.
Close might be 8ohm TG9FD. But can’t find those anymore. Next in line would be a TC9FD and reduce the attenuation resistor in the XO to compensate for the -2dB lower sensitivity.
