Hi. I'm new on this forum. I'm a little "off-topic", because I'm a Car Audio competitor.
But now I'm making a new system. 2 ways + subwoofer.
I need your advice. Car audio needs a good off-axis responce, so the choices are:
Tweeter: Scan 2095/9700 or the 2094/6000-01. Can someone tell me some something about the sonic difference of this tweeters? Witch would you choose? I know the 6000-1 are a newodimium type (and have a little better off-axis response), but I'm concernig detail and image.
Mid/bass: Scan 15w/8530K00. I don't know the difference to the 15w/8530K01, and would appreciate some comments. I choose this driver because is small and have a good bass response.
Sub: Need advice of a 8" (20cm) for a small box...
Crossover frequencys (all active):
Sub: 70Hz and down
Mid: ~70-2000hz
Tweeter: ~2300hz and up
There is a little difference on the mids to highs cut, because of a little peak on the woofer frequency responce at 2Khz. Need to check this with the RTA.
Thanks for your time. All replys will be very apreciated,
Audiolover
PS: By the way, I'm Portuguese. Sorry about my bad English...
Sub: 70Hz and down
Mid: ~70-2000hz
Audiolover
