SB Acoustics SB65WBAC25-4 - What to do?
Thanks for the data and info!
I'm less concerned about lobing in the vertical plane, so long as the main listening area is covered reasonably well (+/- a few degrees vertically), but horizontal lobing is more detectable. I'm also hoping that the diminishing hearing acuity in the HF range will help to hide the transition.
Looks like some experimentation is in order.
All the best,
Chris
I made cardboard box for instantly.
This is a fun driver!
I believe that enabling make it much better.
I want to have advice for designing small vented box.
This is what I simulated on hornresp.
There is bump at bottom.I am not expecting flat response for this small driver.
A tuning of 75Hz gives the shortest spike, but still not ideal.
Hornresp gives a sharp spike, WinISD only gives a small humps of a couple of decibels. HornResp is a much newer sim package and well supported. So, I would tend to believe it.
I don't think "above" 115Hz qualifies as bass. Let's face it. A single SB65 will not give meaningful bass, even sitting very close to them.
They are best used when supported by something with more meat below. Free them around 250Hz or above that, and they will sing.
Greets!
Simple enough; 'sound is round', so SoS/pi/desired diameter = Hz and in theory the driver is pistonic from Fs to either the VC dia. or oversize dustcap, whichever is larger, but the reality is that ofttimes there will be breakup modes due to diaphragm design to maintain a nominally flat response as sound power rolls off with increasing frequency, polar response collapses, so historically 'we' used a mechanic's stethoscope to find peaks/dips/whatever in the response, though now there's powerful computer programs to measure, map drivers/whatever to high resolution, though others will have to help with that.
  • Thank You
Reactions: 1 users
