Sausui 9090 Bias issue
Just recapped driver board on sansui 9090(non DB version). I am able to get 50ma on left channel but only 43 on right channel(pots are about as low as they go on both sides-10ohnm and 2.7). I had also replaced 4 shorted outputs on the side that is slightly low. I can find no resistor out of spec on either side. They are supposed to be within 1ma of 50ma. Any suggestions on what could cause this?
Jon Snell:Went ahead & put in new diodes. Had no effect. Any other common failures?
NigelWright: My transistor checker is broke. Any other way to check gain on new transistors. They appear to be NOS sankens. I used same part number not a sub.
I reversed sides with the driver board & problems remains on that side so guess driver board is OK. Does this mean output transistors I bought off ebay are fake or bad? They certainly look like new old stock. Paid $30 for 4. Is there a modern equivalent? 2SC1116A were originals.
Since the idle current is so close and you ran out of adjustment you can either increase R33/34 OR decrease R35/36. Basically the base of TR07/08 is too positive. For modern replacements, may or may not fix the problem, you can try MJ21194, they are cheap and available.
Craig
How thick are the mounting bases of those xsistors? Real SanKens are a tad over 3mm thick. As far as reliability, if they're fake who's what they really are, could be overkill or not even close.
Can you post a pic of them? I have some real ones to compare.
Craig
Here is pics. Measured .55 drop with diode test out of circuit.
My examples are at work but those look pretty damn good if you ask me. Thick mounting base, lots of little nicks in the base, small diameter glass seals around the pins, and they seem to measure OK. I'll comment about the lettering in the morning.
I would do the resistor change I mentioned, move up OR down to the next value depending on what you have on hand. I usually use a decade resistor so I end up with the pot in the middle of it's travel. I was working on a Marantz 2275 yesterday and they used a 2.2k pot where all the amp wanted was about 50 Ohms, very touchy towards the end of travel. Knowing it only needed 50 Ohms I would use a 100 Ohm pot, puts the wiper close to the middle and not touchy.
Craig
