Hello!
I recently received an old Sanyo tp220 turn table. I know its not that great - but it was free! I have had it up and running with the only issue being it seems to play at a slightly higher RPM than it should.
Before i go pulling it apart can anyone offer advice on what to look for? I dont know when it was last used extensively. I originally thought perhaps the motor was for a lower voltage but according to the back it is rated for my local mains 240v.
Cheers!
Cheers!
Vinyl Engine has the service manual:
Sanyo TP 220 - Manual - Belt Drive Turntable - Vinyl Engine
All the speed control is in the motor. There's two trimmers. I can't make out where they are on the actual machine. Register and download the manual, it may be clear with the beast in front of you.
