Sansui TU717 Rack Handle
I don't know, I am getting into old equipment big time.
The schematics show an attention to the circuitry that is simply unimaginable in today's equipment.
The circuitry may be misguided and not yield the best sound but I value and appreciate the effort by the engineers and the material used very much. They did the best they could with what they knew and I am akin to that.
I am planning to check it out and then replace the power supply diodes with schottky remove the snubbers, filter caps and signal path caps.
I may play with the narrow band murata later.
The tuner info website has links to places where you may be able to get the lights you need. It's an antenna place.
Hi Grataku,
How did you do with your TU717 mods? Did you do the Schottkys? How did that impact the sound?
I just bought one and another member here, Serratoga, is just starting the whole process with his! Any pointers would be appreciated!
Thanks!
Regards//Keith
