SanKen transistors (A1492 & C4883A)
Hi all, new poster...
I couldn't find anything on this but do please point me in the right direction in case I've missed it.
Am having problems locating a supplier of SanKen transistors in the UK. I only need two, an A1492 and a C4883A. I believe the actual model numbers are 2SA1492 and 2SC4883A respectively. I have the data sheets from SanKen but the only supplier I could find was over in the US and only in quantities of 25 or 50, at a minimum cost of $113.50. Surely there's a supplier of smaller quantities?
FYI, the transistors are from a Wharfedale EVP-15PSB. One leg of each transistor has broken away from the body, causing the speaker to cut in/out, quite explosively.
Thanks for any help you can provide.
P. Forrest
