I have just repaired a very nice pair of Allbarry 1008 power amplifiers
These are a nominal 100 watts rms each into 8 ohms
origionally they used 2 pairs of TIP142/147 each
I told my client that I would not! repair using the origional output devices as they were overstessed re max operating voltage etc
So after a little research I decided to use 2 pairs of Sanken STD03N /STD03P
These feature on chip bias compensation and a very high gain of about 8000 rather than 1000 of the TIP142/147
The origional vbe multiplier was removed and the Sankens fitted bias being set via a fixed value resistor
it was very easy to set and rock solid at 15mA per device
The result ? stunning what a buy the amplifiers now perform better than ever before smooth highs and a really tight firm bass
This is a device I shall look forward to using again after spending 20 years of disliking power darlingtons I am forced to review my opinions
The amplifiers are running into a pair of Gale 401/2 a known difficult load
4 hours of loud listening and the heatsinks are just warm showing great bias control
Have any of you used these devices?
These are only half the price of a comparable mosfet and apart from a resistor come complete with bias and driver
regards for now
Trev
regards for now
Trev
regards for now
Trev
There are several threads here about them and their predecessors the SAP's. A search should show them if you are interested.
I used them in my error correction power amp http://www.linearaudio.nl/pax-1.htm
jd
jd
You are correct re oscillation however it has not proven to be a problem in this case
I have full facilitys to scopes and test instruments distortion measuring equipment etc . the amplifiers are very stable re open circuit or into loads as low as 2 ohms I did not test lower than this
The Allbarrys have a lock out protection system that shuts the amplifiers down if the load impedance is to low
I have been very preduced against darlingtons but Sanken seem to have a practical solution at a low cost
regards Trev
regards Trev
