Sanity check on compression drivers for 811B horns
No, it's not used for hifi Greg. I believe you have seen the Altec 828 box with the 511/811 horn combo mounted on top a few times.
Now that I think about it, it's actually the Selenium 250 mid driver using the adapter on the 511 horn. The 205 is a bolt on. Sorry for the confusion.
Yes, do recall now that you mentioned it, 🙁 just didn't put it together with this thread. Don't remember seeing a 205 in my recent search, all the 1" I found are screw on.
GM
Here is the (now discontinued) D205Ti bolt-on.
Here's what I did for an adapter if Tjj is interested.
Start with a plastic PA speaker pole mount and modify it by cutting and adding set screws to grip the driver.
What are your thoughts about this adapter from amazon?
Amazon.com: Screw-On Adapter Plate for 1 3/8" Driver To Fit 1" Bolt-On Horn Flare (Metal): Home Audio & Theater
For 10 bucks a piece, Im not sure I can DIY a better adapter for cheaper.
The only hesitation I have with these adapters is that the price doesn't make sense. That is a nice hefty chunk of metal for 10 bucks. Seems odd.
Considering they are selling complete 1 3/8" thread on drivers for only double that cost, seems like a "sensible", comparatively high price.
Hopefully the bolt holes line up with the threaded hole, and the threads are clean.
Good deal. For $10, I think I made about $2/hr making my own 🙂
Easily measured on the horn before purchase. That said, there were standards for that sort of thing. The D205's (upper horn) bolted right on to the 811.
