Samwin SW50N06
Could I sub in IRF3205 to replace samwin SW50N06, if I also replaced the gate resistors with 47 ohm? I have IRF3205's on hand but not SW50N06.
I think it should be OK with the 3205s and 47 ohm gate resistors. If the FETs run hot at idle without excessive current draw. change the 10k resistors in the photo to 1k. This is based on the assumption that the 10k resistors are connected between pins 9/10 and ground.
The drivers may have failed. The BD140 is a good sub if the originals are not readily available (don't buy from ebay).
As a side not, if you take the photo from a slight angle instead of straight on, you will avoid the flare from the flash.
