Samson Servo 120A knob removal
First post here. I have a Samson Servo 120A with an open led. I have removed all the screws to get to the front panel board so I can replace the led but I cannot get the knobs off the pot shafts. They are very tight and in the past I have pulled the shaft out of pots when they were like this! Yikes! Any suggestions? Thanks.
The knobs on this amp are recessed so can't get behind them like that. I took a dental scraper and bent it into a shallow 'J' shape and managed to get it into the shaft hole from the rear between the pc board and the fascia and it allowed me to push them off the shaft. It was like a Chinese finger toy where pulling on them would not budge but pushing on them worked. Strange. Anyway they are off now thanks for replying.
I've been using my front teeth the whole life for removing wire insulation and so far replaced only two. These don't hurt anymore.
By the way I have an appointment tomorrow with my dentist. Annual check-up.
Let's hope he doesn't need to drill to much.
