Hello everyone, happy new Year!
I was thinking about bringing every LED from my amp (F4) to the front-panel.
That is, 2 from the universal PSU, 2 from the amp-channels, and (?) 2 from the speaker protection (if they light up at all) - so 2 or 3 different sources.
Brightness will be adjusted through resistors.
Will their respective brightness be the same (with the same resistors), or will they vary depending the source (PSU/OS), and I'll have to experiment until it's right?
The resistors can be with the led on the frontplate, right?
TIA
david
TIA
david
If the LEDs are the same then the brightness will be the same assuming the same current is flowing through each one. Say 10 - 15mA.
