That's a very good DMM. Top of the Brymen line. They also introduced a midrange model, BM789 it is called. A friend got one recently and I played with it, its nice enough. Not dual display as yours, but smaller in dimensions.Measurement with the best multimeter available on hand.
Yes left only C-CMC and reg c1Is that simply a passive filter external raw PSU with RC and common mode chokes? If yes its normal to drop on its RC as you up the current load.
What happened to this Mastech's case bumper? Some external element corroded it or it broke down by itself with time like foam does?Old tester
That's the main reason togheter don't trusted some Mastech measurements.What happened to this Mastech's case bumper? Some external element corroded it or it broke down by itself with time like foam does?
Only without RC...More raw DC ripple without the CRC filter of course.
It's C1 at Ubib, not enough?Maybe a cap after the choke could bring some filtering back
PSU
Now = 10.000uF // CMC
Before 10.000uF // 3R // 4.700uF // CMC
C1 Ubib
Now 1.000uF
Before 2.200uF
- Power Supplies
- Salas SSLV1.3 UltraBiB shunt regulator
