you can se I measured at 3 v and 5v:
http://www.diyaudio.com/forums/powe...ic-salas-low-voltage-shunt-regulator-302.html
And this is the circuit Salas low shunt Out 3V to 25V
I would like 2.
I'm assuming that after the GB the boards will also be available on the web site; is this correct???
I would like 2.
Im not sure! Only in the GB
1. Information
Please see more information:
http://www.diyaudio.com/forums/quanghao-audio-design/171999-dac-ash-dac-end-2-up-date.html
http://www.diyaudio.com/forums/powe...listic-salas-low-voltage-shunt-regulator.html
http://www.diyaudio.com/forums/quanghao-audio-design/155960-old-thread-dac-end-andrea-ciuffoli.html
Salas Shunt regulator module for Clock, DAC, Phono, Pre:
Out put from 3V to 35V
Only in the Group, not in my web
2. The PCB has the following data:
3. The price includes:
1. One Set + Worldwide shipping + paypal fee = 18 $/ One Set
2 . Tow set + Worldwide shipping + paypal fee = 34 $ / 2 Sets
3. Over 3 set.....+ Worldwide shipping + paypal fee = 16 $/ one Set
- -1 x + 3 to 35V,
- -1 x + 3 to 35V,
- -1 x -3 to -35V.
- - Material: FR4 – 1.6mm
- - Layers: 2
- - Board size-One set: 150x126 mm (You can split into three separate PCB)
- - Surface finish: Immersion Gold
- - Copper weight: 70µm
- - Soldermask: Both sides - Red
- - Silkscreen: Legend on top
I just created on diyaudio, not sold on my website
Please Update the list yourselves when you type here:
1. wendell c : 1-2 set
2. andRookie : 2 set
3. andRookie : 4 set
4. sandbasser : 2 set
5. daanve : 2 set
Total GB : 11 set (minimum order must 50)
5. daanve : 2 set
One set have 3 module Salas shunt regulator
1. -1 x + 3 to 35V,
2. -1 x + 3 to 35V,
3. -1 x -3 to -35V.
1. wendell c : 3 set : 48
2. andRookie : 2 set : 34
3. df_genius : 4 set : 64
3. sandbasser : 2 set : 34
5. daanve : 2 set : 34
Total GB : 13 set (minimum order must 50)
1. -1 x + 3 to 35V,
2. -1 x + 3 to 35V,
3. -1 x -3 to -35V.
the layout Is not flexible If one like to use bigger heatsinks can you fix this
also led string as a voltage ref will be fine option
does layout accept Nichicon KG
Yes!
That is the sample Last layout of Salas low shunt for DAC-End!
- Group Buys
- Salas low shunt Group-design by Salas
