This one is cheaper, and probably works OK: BlackJack SolderWerks BK4000 Thru-Hole Desoldering Station
Attenuator/pot for balanced setup
Hi all,
my first post here and thanks for all the insights I was already able to gather on this thread. Quite amazing, really.
Just ordered two pcbs from Tea-Bag to build a balanced device.
What stepped attenuator/pot do people use or recommend for a balanced setup? I understand it should be 20kOhm.
I assume price is also a factor here ... so, also thoughts on price/performance welcome.
Did someone make comparisons?
Thanks,
lugili
Hi all,
Thanks,
lugili
DC couple the scope input for under 200ΗΖ squarewaves. They got a small value capacitor normally on AC input position.
The long run DCB1 subjective feedback merits the bass area so a feeling of lightness there its possibly due to a peripheral circuit or 600 Ohm input amplifier? On anything > 5kOhm it should do well.
Make sure that the input impedance of the LDR is easy on the source equipment used.
Also high hot-rod enhances the feeling of tonal completeness. Let it run in its electrolytics first before any further mod planning in any case.
Thanks alot. Got rid of the LDR volume control and just use a TDK cp2511 pot right now. No lightness in the bass. That is for sure 🙂
Have ordered a 25k log stepped attenuator to test.
Will take the ldrs to the bench and do some measurements and work on it before trying again.
Hi all,
Welcome to the forums. There are a few members only with balanced DCB1, hopefully they will give you an opinion if they read.
My diy LDR volume control measured DC resistance 11K-13K ohm all time from complete range of volume.
Sent from my iPad using Tapatalk
Scorpion, I forgot to ask you, are those hefty double mono pots you installed via brackets Penny+Giles or something?
LDR will be hard to use balanced since the Silonex NSL-32SR2 are biatches of being unlinear to match over full spectrum. Single ended they sing very nice tho, and can be confed very low, to the kilo if needed.
Salas I havent forgot you, I have a guest and match on when I have the time. Im up to some 25ish different pairs now, closely matched at different voltages and biased. The hard ones in both pentode and triode mode. Some 10-15 to go before I ship. Have put some D3As, C3Gs along with other triodes, tetrodes and pentodes to try out.
Hi Salas,
Nope, the double mono "pots" are TKD P65CS stepped attenuators @20K. Bought from Michael Percy.
The "brackets" are hefty machined aluminum chunks I made. Wanted the stepped atts as vibration free as possible
Scorpion
No worries, since no imminent plans. Just stashing some good samples to be handy for possible ideas.
Xactly what i thougt. Thing is when i find a new interesting ones there is hundreds of it and I need to match them all. I just found around 6000 ecc81 in some boxes. Measuring some Sylvania now. They are all over the place.
Never got an answer to the questions above, so ordered a 10K pot from tocos. Got it today, and could not believe my meter when discovering a difference between the two resistance tracks of 600Ohms. Corrected this by soldering 600Ohms resistor between the signal in, and the pot on one side. Tracking is really good now.Salas and AndrewT, thank you both for the insight.
I measured the output of the Squeezebox, it is about 8,5 Ohm ( yes, that low )
Checking a couple of service manuals that I saved gives the following:
Philips: range from 120Ohm to 1K
Pioneer does not specify anything
Technics SL-PG490 says 1K, load impedance greater than 10K ( here's 1:10 )
Sony only specifies output voltage at 50K, and says load impedance greater than 10K.
When I demo the repaired players they can be connected with a 50 cm interlink of standard plus quality ( simple interlink but not the very cheapest type that fall apart by looking at them ). I cannot demo with expensive interlinks because they grab the connector with too much power to easily put them on and off the gear to be demonstrated.
Will 10K be fine ( enough for demo purpose? )
For personal use it is only the squeezebox, and that will be 1:100 so more then fine
Time to listen, and I am torn by the result. Mids and highs have opened up very nicely, like that. But it has cost me the nice energetic bass the system had when the 50K Alps Blue was in there.
Adding a 10K resistor in series did not alter the sound so much I could hear it, so tomorrow will add another 10K to see if enlarging the resistance brings back the bass drive.
A few months ago I tried a parallel pair of 47K metal film resistors feeding a 20K Tokos Cosmos RV24 pot and I am quite impressed by the result. Lovely tone and detail but the bass is more powerful especially at low volume which is very nice.
Thanks for your reply Davym!
During my lunch break I added an extra 10K, and that brought more energy back into the bass, although I really start to notice that I need to turn the volume up further to get the same sound level.
Perhaps it will be better to buy the 50K Tocos, hoping that the mids and highs will stay at the same level. Another idea would be to feed the signal straight into a DCB1 to buffer it, then to the 10K potentiometer, and finally to a second DCB1 to lower the output impedance.
Any ideas about what is the best solution?
Strangely enough a 50K Tocos pot arrived here two days ago from an ebay seller in Taiwan called wonderco-buy, I have not had the time to try it yet but it was not expensive and only took about a week to get here which was surprising. I was using miniature DACT stepped attenuators in my projects but I much prefer the sound and fine adjustment from the Tocos, providing the channels are not too mismatched, it's a far better pot. I have only tried the pot's on the input of the DCB1 so far, not sure about connecting one to the output but I might try that at some point. Maybe Salas can advise about that, I am under the impression that it's best to keep the current across the carbon track as low as possible.
davym
Keep it on the input.
Jslot
Adding a stage should be less transparent than having a bit slower rise time with 50K when you can't have 20K and your sources don't give good bass on 10K.
Jslot
Thanks Salas!
Davym, I am very curious how the 50K Tocos will do in your system! I bought the 10K from the same seller, and he is very fast indeed!
The low price might have something to do with the quality, the taper closest to the shaft measures 600Ohm higher than the back one. Tracking is ok after soldering a 600R resistor in series with the back taper. Could you measure your 50K pot before mounting it?
Salas - cheers mate that confirms what I thought.
jslot - I noticed the same tracking problem with the original 20K Tocos pot I got from hifi collective last year. I complained and got a full refund and an apology. I got another 20K Tocos from ebay (cant remember the sellers name) and it was the same. I found it a problem at very low volume, one channel would cut out completely before the other. I started using the miniature DACT pots but as usual fine adjustment was an issue and they sound quite harsh in comparison with less bass clout.
Pre loading the 20K Tocos pot with the paralleled 47K resistors made it very useable range wise and solved the noticeable imbalance at very low volume but I still ordered a 50K to try. I'll measure the 50K one later (if I get time) and get back to you.
- Analog Line Level
- Salas hotrodded blue DCB1 build
