I would like to ask whether smoke from burning silicone grease is toxic or in any way dangerous to health.
Today, I modified a soldering iron which had a stuck soldering bit. I sawed the exposed part of the soldering bit and fixed a brass imitation of the part I sawed off. To help heat conduction I used silicone grease between the remainder of the original bit and the imitation part I made. However, when power was applied, the silicone grease started to burn with an extremely pungent smoke.
I would like to ask whether this kind of smoke is dangerous? I know that some elements/compounds are extremely damaging to health, even if contact is for a few moments.
Is it all right to use brass as a material for soldering bits?
Thanks for all your replies.
Yes, but see my previous post.Is it all right to use brass as a material for soldering bits?
