my multimeter says open even my LCR meter say so
Then if only one channel is damaged, measure the inductor in the good channel,
and replace both inductors with new ones. Don't try to wind 1400 turns yourself.
i got a motorized winder with counter but not a torroid winderwell all the inductor were damage
yes I did do the math, but you need to also know the DCR value of the inductor
so you could estimate the Q of the LC ckt
Hi all,
Anybody knows the inductor values of an SAE Preamp Mark IXB eq section? or service manual, I am currently restoring one and i am trying to wound my own coil using EPCOS P26 cores. Any info would be highly appreciated.Thank you.
it is a 7 band eq with non ISO center freq 40hz, 120hz, 320hz, 960hz, 2500hz, 7500hz, 15khz i love the sound of inductor eqs similar to those manley passive eq, pultec amd rupert neve designs for me thisnis the real tone control before the simulated inductor become mainstream aka gyrators
Dear,it is a 7 band eq with non ISO center freq 40hz, 120hz, 320hz, 960hz, 2500hz, 7500hz, 15khz i love the sound of inductor eqs similar to those manley passive eq, pultec amd rupert neve designs for me thisnis the real tone control before the simulated inductor become mainstream aka gyrators
